jcatnite
Well, the engine is out of Rusty(bout 2.5 hours to pull engine and transmission). I've broken the top end down and seems that I have a fairly worn little engine. After I pulled the rocker shaft off, I could grab the flywheel and rotate the engine pretty much freely with the plugs still installed...lol. I can see that the clearance between the pistons and the cylinder walls are what I would call extreme. The number 3 exhaust valve is black and oily (not firing?) and there is about .060" of carbon built up on the top of the pistons...lol. I only post this to say that it was a miracle that the little engine could generate enough power to pull the car down the road. All in all, I thought it still made a good amount of power so I can't wait till it is renewed. Morris, the front nut came right off after a couple of clacks with my $60 impact wrench from lowes, same for the flywheel bolts. I also have scratches perpendicular to the crankshaft but they aren't too deep. I can't catch my finger nail in them so I doubt they are more than about .005". The ridge at the top isn't too bad either. I tried to measure the bore but couldn't operate my inside mic inside that tiny cylinder...lol. Guess this is just a progress report but I'm excited to see that the internals are in pretty good shape and wanted to share.
JC
JC
