And a setback
fabmandan
I've been e-mailing Gerard Chateauvieux of Gerard's Garage fame about my brake situation. I have the stock 948 drum brakes. I also have a dual 3/4" bore master cylinder that needs to be sleeved. Gerard talked to Joe Way from Sierra Specialty Automotive and he thinks I should not run the smaller cylinder with drums. He thinks I should put discs on it. I had planned to put discs on it but probably not this summer. I can't afford that along with everything else.
Should I try to find another master or try to run the one I have. Joe thinks I will have a reaaly soft pedal.
Any Ideas?
Thanks
Dan,
I'm sending you a PM, we may be able to help each other...I am the complete opposite of you..have discs and a 7/8" master (newly re-sleeved).
