Ed_K
I agree with Greg and Keoke,
If you are considering buying and then adding a gauge to use to
monitor your car's electrical system, a volt meter is a better choice for the reasons mentioned by Greg and Keoke.
If you already have an ammeter, Greg showed the best way to
hook it up.
A voltmeter is a good indication of the overall " health" of your car's electrical system.
That Smith's voltmeter that Moss sells looks like an exact match for the BJ8 black gauges and it is lighted ( just install the same LED as discussed in Roger's LED upgrade and then it will be a perfect match ). You don't have to run heavy gauge wires through the firewall to hook up a voltmeter. Just connect one wire of the voltmeter to one of the green switched wires that is
only on when the ignition is on. The other wire goes to ground. Attach the light wire to the string of other dash light wires ( red and white ).
Done.
hook it up.
Done.
