See what I mean about it never ending with these cars???
Let's see if I got this straight:
1. Buy new aluminum valve cover & gasket - $170.00 plus tax & shipping. (Assuming that you have clamps, clothes pins and gasket shellac)
2. Install, admire for about 300 miles and discover oil leaks or excessive consumption now occurs. Use up all extra V/C gaskets trying to get them aligned properly. Order more gaskets at $2.95 each, plus that infernal shipping cost.
3. Take old cover to platers to be rechromed to replace leaky oil consuming new aluminum valve cover. Another $125.00 plus tax and another $2.95 gasket and extra nyloc nuts for another $6.00 plus the ever present shipping.
4. Spend $200 for a separator from Richard Good and pull the oil pan to have a bung welded in to reroute oil from non baffled $170 valve cover back to crankcase. Parts and labor will be another $150 for that plus the shipping to get several new oil pan gaskets in because you just know that they are gonna leak!!!
OR
5. Pay a machine shop to level the new "twisted" aluminum cover on a plainer and CNC in a groove to allow a new style seal to be installed (which has yet to be found). That could cost another $200.00 unless you are holding machine shop owners wife and daughter hostage, in which case you may not have to pay that stupid shipping.
Or you could invest in or buy a machine shop so that we could all ask you to do work for us for free to fix something that should be trouble free and easy to install as you bought it!!!!!!!
That will only be $500K to $2.5M, just to fix an oil leak and look good doing it. It never ends..........
