Aluminum or steel rivets?
svtmikey
I am putting a new steel battery box on my 69 GT6 and I was wondering if it matters what type of rivets I should use?
I have heard that if I use aluminum rivets on the steel battery box and car body, it may set up some sort of electrolysis between the two metals and start corroding.
Also, I have heard that on steel rivets, only the post is steel with the body being aluminum anyway.
Anyone know for sure?
Thx
Mikey
DougF
How about body adhesives? A supplier of automotive paints would stock it. It would be stronger than rivets, leave better looking results, and be easier to work with.
If rivets are the only choice, I would use steel/steel. They are stronger though they are prone to rust. Make sure to get a good coating of paint on them.
The rivets I sell are either aluminum rivet/steel mandrel or steel rivet/steel mandrel. And then there is stainless...
angelfj1
Thx
Mikey
Mikey
Are the rivets to be used as a permanent fastener or will you also be welding the box in place? In the presence of battery acid (possible overflow) I would not recommend rivets. Have it welded and have the seams properly sealed.
dklawson
Use either one you would like but seal the seam between the box and the bulkhead. Then... order the plastic battery box liner (from Moss or elsewhere). It kind of kills the drain tube function of the steel box, but as long as you don't puncture the plastic liner you won't have any more rust to deal with either.
TR3driver
Great Pumpkin - R.I.P
:iagree:
on all counts. Adhesive sounds like the way to go (since you apparently don't have welding available), and aluminum pop-rivets are aluminum.
Dissimilar metal corrosion occurs between aluminum and steel any time they are in electrical contact; not dependent on water (or battery acid). But it usually proceeds very slowly; generally the aluminum forms a layer of aluminum oxide that functions as an insulator, so you may be OK as long as vibration, etc. doesn't keep destroying the oxide layer.
bgbassplyr
Rivets are available in aluminum, steel, stainless, and copper for sure. Post is steel on most to insure the correct pull on the rivet.
Use alum for alum, steel or stainless for steel, copper for copper, etc.
If you rivet the battery box in permanetly or for later removal, just seal it to the bulkhead and rivet every 2" o.c.
Remember that many, if not most or all special built race car-formula car bodies/ monocoque chasis are riveted.
TR6oldtimer
Submarines are welded...
tinman58
When I installed my battery box it was seam sealed in place. Then I drilled 3/16" holes and installed chrome allen head bolts. (S.S. battery box and chrome bolts gotta have a little bling)
dklawson
The problem with stainless around the battery is that 300 series stainless (and less expensive 18-8) is going to be attacked and loose its shiny appeal after exposure to battery acid. I'm sure it will hold up better than mild steel, but without the protection of a plastic liner (or perhaps a real high-end battery) it's going to look rough in a while.
KVH
When you guys talk about welding the battery box in place, do you mean a few spot welds, then with sealer and filler, or do you mean a solid weld, continuous along the seams, then ground smooth?
[The question might give away that I'm not a welder]
dklawson
I have only seen the battery boxes spot welded in place with seam sealer applied prior to painting.
svtmikey
svtmikey
The battery box that I am replacing was rivetted in place and I am pretty sure it was original, as most of the car is. I am not going to put a battery in it anyway, as I will be moving the battery to the right rear of the car and putting it in a battery case. I had thought about welding it as well, which I can do, but I think that's too permanent.
Having read all the input above, I think I'll most likely seal it with a good seam sealer and rivet it with steel rivets.
Thank you all for the input, I LOVE THIS SITE...it's the only place around you can get this type of input from so many people with so much experience!
I hope the New Year is the best ever...I know I for one am happy that 2009 is over!!!
Mikey
trfourtune
spot weld, otherwise you will probably warp it.
R
ps- i like to drill small holes in one panel then spot through the holes.
svtmikey
svtmikey
I think that is actually called "plug welding"...I think I use a 5/16 or a 3/8 bit to drill the hole, that seems to word quite well. Start your bead then move it in a circular pattern to fill the hole. I also have a spot welder that is basically 2 welding prongs that you close on each side of the two panels that you are going to weld,pul the trigger for a second and bingo. Mine is a cheap one I got from Harbor Freight and is a 110V version. They also have a 240V version, but the 110V worked just fine.
On my floor pan replacemnt I did a combination of both.
Mikey
trfourtune
I use 1/4" or less depending on what it is.
R
bgbassplyr
startech47 said:
What diameter hole do you drill?
Same size as the rivet you're using, ie, 1/16, 1/8, 1/4, etc. The rivet should fit tightly in the hole so that there can be no movement between the pieces being joined.
Drill the first hole and install the rivet.
Drill the second hole and install the rivet.
You can then drill several holes before riveting.
It's hard to drill it all before riveting and keep all the holes aligned. There is a tool that is used to to hold the work (the name of which escapes me at the momet), a push to install, push and pull to remove. Someone will know and post the name and where to get them. Prolly search Eastwood for pop rivets and it will be there. With no more than you are going to rivet though, you won't need them.
fad64b Bonnet Steel versus Aluminum MG 4
C Door hinges - steel or aluminum? Austin Healey 9
911cop Steel and aluminum reaction Austin Healey 4
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
