I started to fit the new oil gallery plugs into the block and found they were a very tight fit. I understand they need to be cut off and sealed, but my wrists are impressed on how tight they fit. I put only 4 threads in on my test fit and it looks 8 threads total, but I can almost see something breaking, maybe. The aluminum shaft should hold and the soft threads thread off and probably make the plug seal better. Anyways anyone else have this problem off everything being so tight. Old wrists might be the problem, and what did you use for a sealer?
Steve
Steve
