Aluminum Finish
Rut
Good morning all,
I'm redoing the aluminum on the Bugeye and wanted to know what the original finish was for both the cockpit surround and windshield frame and posts. I'm either going with original or have it polished and anodized. Also, any recomendations on who to do this type of work? Jack gave me the name of a place in Florida and they do good quality work, but it would be nice if I could find something closer.
Thanks, Rut
PAUL161
As I remember them when new, I believe it was anodized like a B windshield frame. Could be wrong though, CRS seems to be working overtime lately! :rolleyes: PJ
jlaird
Cockpit surround, doors and rear were anodized, front covered with interior color vinyl. Windshield posts light gray paint.
Rut
Rut
Jack,
Thanks for the info. As we discussed I contacted the people in S FL regarding anodizing, but I don't know if the aluminum should be a high polish, med, low, sanded, bead blasted, etc. I've seen just about every type of finish out there and they all need to be re-anodized or they will oxidize in a hurry.
Thanks, Rut
regularman
I have done it, but its hard to get the anodized off of aluminum. You have to use oven cleaner, drain O,etc. Then when it is removed you can polish the aluminum like chrome but it doesn't have any of the protection of the anodized aluminum and will get real ugly in a hurry.
I did this with my grill surround on the 71 midget but I clear coated it with some stuff about as soon as I got it polished.
If that company removes the anodized and then can re anodize then that is awesome.
Rut
Rut
Kim,
That's my goal to have the cockpit surround and windshield re-done by a shop and re-anodized. My main question is what finish is original? Brushed, polished, bead blasted, etc. and does anyone have a shop that they would recommend?
Thanks, Rut
rkep01
Rut - Might want to check this out. Far cheaper than anodizing. If it doesn't work, you could always go back to anodizing.
Rut
Rut
rkep01,
there's no link or anything with you reply.
Thanks, Rut
RickB
rkep01 said:
Sorry 'bout that. I'm sure I'm pre-alzheimer's. Here's the link: https://www.sharkhide.com/
The correct term is: Mild Cognitive Impairment
Then there is also CRSS
Can't Remember 'Stuff' Syndrome
rkep01
Think I have all three :jester:
dklawson
If you take the frame to the anodizer they will be able to strip the old anodizing off. What is left will be a satin finished bare aluminum (much like what Kim will get from using oven cleaner). That can be anodized again as is but it will have a matte appearance. Most platers are not going to polish or otherwise prep the surface for you but it is certainly worth asking about if you don't want a matte finish. If they won't polish the frame you will probably want to take the bare aluminum home and polish it to the level you want, then take it back for final anodizing.
When you discuss anodizing with them there is soft-coat and hard-coat. The hard coat will be thicker and last longer but cost more. It also doesn't take color as well. However, the surface of the hard-coat can be filled with things like Teflon to give it long lasting protection.
Rut
Rut
Guys,
Thanks for the replys and the Sharkhide looks very interresting! My goal is to replicate the original factory finish either myself or have someone more experienced do it and have it anodized. I'll call around to the people who advertise anodizing and find out what services they offer and research the original finish/texture prior to anodizing.
Thanks for the help! Rut
jlaird
Polish Rut. the outfit I pointed you to will have the whole thing done, call em.
Rut
Rut
Jack,
I thought I could find a place closer and wanted to check around. Now I understand why you used them and I'll give them a call when I get to that point (hope sooner rather than later).
Thanks, Rut
jlaird
LOL, Kay said Miss Agatha deserved only the best.
G
dklawson said:
When you discuss anodizing with them there is soft-coat and hard-coat. The hard coat will be thicker and last longer but cost more. It also doesn't take color as well. .
Never heard of soft coat before. I guess they don't leave it in the tank as long. If he's "clear" anodizing it color with be the same as they don't use dye for that. I anodized some stuff at home before. It's not that hard but time consuming getting everything set up right. The problem is getting a container big enough to do the surround. That's a lot of acid too. I'll probably cost the same either way.
smaceng
Anodize is usually called hard coat. the problem with anodize is that the color result is not what you may want. It is best to have a sample done to check out the color...and what I really mean is shade...usually a bit grey.
Soft coat is called iridite, which is a similar process, i.e. the ozidation of the surface layer...but a thinner layer. I would suggest this as it protects the surface from further oxidation, and gives less grey to the surface. Also, a good layer of wax is good too. That is what I did to mine. So far so good after 1 1/2 years.
Scott in CA
Rut
Rut
I think I'll follow Jacks advice since I've seen Miss Agatha in person and the finish is exactly what I want. Original with no imperfections, good protection, and decent turn around. I just wish they wern't so far away!
Thanks all, Rut
5 sidescreen aluminum finish Austin Healey 8
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage MG Classifieds 1
WHT For Sale Montrose Enclosed Aluminum Trailer - 76-inch Height Fits In Standard House Garage Austin Healey Classifieds 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
