aluminum BE radiators on ebay, drain plug thread?
TulsaFred
I installed one of these units and it works well. The one I bought has a plastic drain plug with an O-ring. Unlikely to hold up and looks wrong. I've been unable to find out what the thread is. It doesn't seem to be an NPT, or a metric thread, at least not one available at the hardware stores. I took the plug to Lowes and tried it in their thread examples mounted in the hardware section - both SAE and metric - and it didn't fit any. Also tried NPT fittings over in plumbing, also without luck. I asked the seller what the thread was and he replied "don't worry about it". It doesn't look to be tapered and it is between 1/4 and 3/8 diameter. I'd like to fit an adapter and/or brass petcock. Any ideas?
https://www.ebay.com/itm/3Row-Radia....TRC0.A0.H0.Xbugeye+sprite+radiator.TRS1.TSS0
I do not know what size it is. However, it looks like there would be significant material to cut some new threads in there.
Do you have a hydraulic store near you?
TulsaFred
TulsaFred
Hi Trevor,
What type of hydraulic store do you mean?
Fred
SD Bugeye
I wouldn’t worry about it
it is fine
plastic plug in radiator would be fine by me
a brass Petcock in an aluminum radiator would worry me more .
Run with it all good.
we use plastic plugs all the time at work
most likely it’s straight cut pipe thread with an oring seal
We have Parker Hydraulic stores here.
TulsaFred
TulsaFred
I'd prefer not to have a plastic plug for the aesthetic on a car of this era, but its no big deal. I would still like to know what the thread is in case the flimsy plastic plug gets stripped or I lose it. Maybe I'll take the plug to a plumbing supply company when I get some free time.
nomad
Sure its not the same thread as the stock radiator pet ****? British Standard non tapered. Just fitting a stock Sprite Brit temp bulb to a Datsun head and the threads are the same.
Kurt
TulsaFred
TulsaFred
Kurt
Not sure, good thought. I did buy a petcock from bugeyeguy.com. It is 1/4 NPT and doesn't fit (too small). I'll look around for a temp bulb to test it. Unfortunately I have to drain the radiator each time I check it...
dklawson
I'd prefer not to have a plastic plug for the aesthetic on a car of this era...
Please don't take this negatively but you have installed an aluminum radiator in the car. The original appearance is already gone.
You said the thread was between 1/4" and 3/8" That's awful small for a normal pipe plug... metric or SAE. Borrow some calipers and measure the thread OD in a few spots and average it. Then take the plug back to the hardware store and compare its thread pitch with every fastener that looks close in pitch (ignore the diameter... just see if you can identify the pitch). Once you have the diameter and an educated guess on the pitch post that information here and I'm sure we can help you come up with something.
BlueMax
A Vernier Caliper, SAE, Metric, & Pipe thread gages should eliminate all questions to what your replacing.
Jim_Gruber
Make it easier just go by a radiator repair shop and you are fixed in just a few minutes.guy charged me $5.00 and done. Same thing for a drain plug on a new gas tank. That cost $25 and about 15 minutes to get soldered it.
kcbugeye1275 Aluminum radiators MG 1
kcbugeye1275 aluminum radiators Spridgets 12
71tr TR6 aluminum radiators - TR6 Triumph 32
PATR8 Griffin Aluminum Radiators Triumph 22
newmexTR3 TR2/3/3A TR3 aluminum replacement radiators Triumph 9
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
S Aluminum wing vents for BT7 3000 Austin Healey 1
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
maxwedge5281 aluminum body parts Austin Healey 15
SherpaPilot TR6 New Aluminum Radiator Triumph 4
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH TR4/4A Aluminum Front Plate from Moss and BPNW Triumph 2
F How to paint/prime aluminum front valance BT7 Austin Healey 2
trotti Aluminum cockpit trim Austin Healey 0
Got_All_4 TR5/TR250 Roto aluminum wheels on ebay Triumph 8
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
maxwedge5281 fitting aluminum wings Austin Healey 5
