Hi there,
I've installed an aluminium oil pan on my 100/6 Longbridge model and have always filled up the oil to the marks on the dipstick.
Last night, I decided to put the exact amount of oil into the engine (12,75 pints or 7,25 litres)and found that the level is now about an 1/8 inch below the minimum mark. I rechecked it after the oil had settled for about an hour and also decided to run the engine (perfect oil pressure after I'd also changed the oil mpressure valve)and no change.
Would this be alright to run the engine like this or should I top it up to the correct dipstick mark?
Does the aluminium oil pan have another oil capacity or do I possibly have the wrong dipstick?
regards
regards
