MadRiver said:
(the 250 has an external regulator, and the replacements, though made in England, are junk in my opinion).
That's strange. My Stag uses a similar (tho not identical) regulator, and I've had no trouble with them. The one I dropped the power steering pump on (breaking it open and dumping PS fluid inside) did eventually fail, but I wouldn't call that the regulator's fault /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
However, I have had several problems with the wiring to the alternator, and one incident wound up frying the control box (which is incorporated in the regulator on your TR250). So my suggestion would be to first give the wiring the "hairy eyeball", especially the ground at the regulator and the brown/red from the regulator to the starter solenoid. Also check carefully the brown/green to the alternator for any signs of a short to ground (which would cause the alternator to go full on).
Then get in there with a good voltmeter, and check the voltages right on the pins to the regulator. With the engine running, you should find exactly full battery voltage on the B+ terminal, and exactly ground on the "-" terminal. Any voltage drop between these terminals and the battery will result in overcharging.
Friend of mine fought a 'twitchy' ammeter on her TR250 for several months, and eventually discovered a bad ground where the battery cable joined the body. Paint on the body was preventing a good connection, as I recall.
MadRiver said:
The battery is relatively new, but I may try swaping it out with the new one I just put in my Tiger to see what happens.
I'd suggest some simple checks first. Check the voltage at the battery with the engine at a fast idle. If it's over 14.4, then there is definitely a problem with the charging system, and no sense changing the battery until it's fixed. Part of what makes these systems so hard to troubleshoot by changing components is that each component can cause the other to fail.
MadRiver said:
(Next the ammeter is coming out for testing.
It's almost impossible for an ammeter to fail, except to go open circuit. Obviously yours isn't open circuit, so this would be a last resort, IMO.
Likewise, if the alternator will put out full current, then it's probably OK. The only possible fault left would be a short to the field (rotor) winding, which you can easily check for with an ohmmeter. Disconnect both field wires and look for continuity from either field terminal to ground.
BTW, I'm not sure if the Bosch alternator will fit the TR250 without modification or not. The externally regulated Lucas 11AC on my early Stag is rather larger than the Lucas ACR models used on the TR6, so the mounts are different. You may need to find mounts from a TR6. Also, of course, the wiring will be different. You'll need that funky 3-terminal plug from the TR6 in order to connect to the Bosch unit.
