Bret
OK – I see what you are talking about. This is the Starter Solenoid Relay. This relay is part of a “standard” low current circuit relay controlling the higher current primary “Starter Solenoid” that engages your starter to the flywheel and connects battery power to the starter.
IMO The starting & charging circuit in this schematic isn’t all that much different form mine. (74 vs. 78) But if you follow the circuit closely – I think you’ll find it would be a little hard for this to cause the problems you’ve had with charging thus far. Even if the relay was bad. Mind you - this isn’t to say that you won’t find more Lucas ghosts haunting other parts of your car’s electrical system down the road. The chances of this happening seem to go up exponentially the further you are from home or a good mechanic. ;-)
Anyway I’m happy to see that your making the best of your time while you wait for the new Alternator. If you haven’t already – go ahead and clean up the terminals as best you can. And look to see if any of your connections need to be re-terminated and/or replaced.
Bret
Bret
