mfmcauliffe
I have had my TR6 since January. No issues until it arrived in MA for the summer. My ammeter gauge sporadically shows positive charging for a moment or two, but mostly it is negative drain both idling and driving. I used a voltmeter to test the terminals while the engine was running and saw no charging. I then used the voltmeter to test the alternator itself and it appears to not be working (assuming I did the test correctly). As a result, I need to replace the alternator. However, when I look at Moss and some other sites, I see a confusing array of choices. I don't think I need to upgrade given the car is a weekender kept in a garage. Any suggestions on where to source? I also may need to buy an adaptor for the plug depending on the alternator (and pulley). Why am I seeing some rebuilt models for $4-500 and the straight replacement alternator for $130? I am using this as my first do it yourself project (40 years after selling my last British roadster). Any and all insights or suggestions are appreciated. Michael
