This goes out to those who have alternators or those who might have an understanding. I switched to negative ground long before I installed my first alternator. I just had to replace it; the first alternator finally lost a diode. I've never had a functional "no charge light" since I made the conversion and to make up for it I put in a small digital voltmeter, which works well. Now, with the new alternator and apparently nothing better to do, I decided to remove the modified regulator I had previously cobbled together to act as a bus bar since I now had an internal regulator. I just spent some extra money on a dummy regulator that has a 50 amp fuseable link ( made by Wosp) and installed the new alternator. Eight years with no warning light was just fine but now I want it to work or die trying.
My issue is this. When I turn on the ignition, I get a nice solid no charge light. When I start the motor, it goes to flickering and never really stays off. Oddly, my cheap little volt meter shows a solid 13.5 to 14.0volts, no jumping around. However, if I measure output at the B+ terminal on the alternator my slightly more expensive dvom flashes voltages between 13.5 and 14.5 flickering very rapidly, sometimes to values slightly more or less than the average 1 volt I see on my dash instrument.
Sometimes the light is off for about half a second, but it always flickers back on, no matter the RPM. My brain hurts from trying to figure this out. The alternator is a Denso, as was used in the '86 and beyond Suzuki Samauri, freshly remanufactured by who ever does that in China and sells them to all the auto parts stores. Nice little unit by the way. It has an S terminal for sensing voltage, which I have not connected, an ignition terminal that turns on the internal regulator, an L terminal which supposedly grounds the no charge light and then supplies voltage when the alternator is spinning, so as to " balance out" both sides of the lamp and cause it to extinguish due to there not being a potential across it. Short of thinking there is a glitch with my new alternator, I'm at a loss. It's probably something obvious but I've already exhausted the internet forums and youtube videos which all make it seem so simple. Any thoughts?
