TexasKnucklehead
Generally when I find something to not be working as I expect, all I need to fix it, is to figure out how I caused it.
I have replaced my generator with an alternator. It came with no documentation. The alternator has three connections for wires (it is grounded via the frame). The largest connection is threaded and denoted "B". I assume this to be the output and it is connected to the Battery (actually the NU/brn-blue wires at the voltage regulator). Two spade connections are grouped, one horizontal and one vertical to accept a connector that could not be installed disoriented. I don't have the mating connector, but 2 spade lugs fit well. Above the connector is marked "IG". I have "IG" wired to a switched hot (ran a white wire to the fused side of the white/green terminals on the fuse block). The other spade connector is connected to the small yellow wire that goes to the idiot light on the dash.
When I turn on the key, the idiot light lights, dimly. The ammeter shows discharge with anything switched on, without the engine running. The ammeter needle moves towards +30 amps as soon as the car starts (it's a 30a alternator) and slowly declines towards "0", never really reaching it. After started, the idiot light gets brighter with the engine revved. It dims as the amp needle goes towards 0 -but the idiot light does not ever go out.
How can I make the idiot light go out?
At first I thought the "IG" was for the idiot light, and I wired it to that, and tied the other spade to B, thinking the 2nd spade was intended to be "Sense". -The idiot light never came on, but the alternator charged. Also, I noted a 1/2 amp discharge with the "Sense" hot wired to B with the engine not running and key off. So I changed it to as above.
The original regulator is still in place, but the F and D terminals have no connections. So it should be acting like a junction box for the used wires (only between A and A1 -even when all three NW+NU+Y are tied together).
Suggestions are welcome.
