I recently converted from a generator to an alternator on my 100M using the Lucas Kit from AH Spares. Everything tested out OK on installation but after driving for several hours, the car died and would not turn over. The battery was dead. I had the battery tested and it was fine and it held a strong charge. I tested the alternator output and it was 13.5v. However, when I loaded it up (turned on lights and the thermostatic electric fan kicked on) the output at the battery was only 10V. Looks like the alternator can't handle the load. I contacted AH Spares to check on a remedy but wanted to check with the Forum to see if there were any suggestions. The electric fan has been a godsend on engine temp so hate to delete that. Not great at this electrical stuff so suggestions appreciated.
Hi Guest!
