RAC68
Hi All,
Recently we discussed the selection of engine oil for our Healeys and, as Healey Nut can attest to, several new informative perspectives were exposed as a result of Bob's reference of the 540 RAT forum (https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/). When considering oil selection for use in the transmission/OD, a search of past Forum threads brought out that, although SAE 30W non-detergent was officially specified back in the day, many have, and are, using everything from Royal Purply and Red Line transmission fluids to various single or multi-viscosity oils ranging from 60W and 20W50 down to 10W30. So, as exposed in the 540 RAT blog, it strikes me that our selection may be able to be more independent-fact based rather than solely reliant on general operational impression. Additionally, by making a selection with the advantage of knowing the lubricant’s Ware Protection Index, an improvement in transmission operational longevity can also be one of the beneficial gains achieved.
When looking at how we have selected engine oil in the past, viscosity, with respect to operating temperature, has been the primary selection criterion. Along with availability/convenience, price and oil company hype. Preliminary selections were made and further evaluated through operating experiences resulting in user recommendations that have helped others to do so. The selection of a Transmission/OD fluid alternative has been typically based upon a more definitive factory specification for SAE 30 non-detergent oil. Although I am not aware of the actual average operating temperature of our Transmission/OD, I expect it will fall closer to the higher (212F) testing temperature than that of the cooler for oil comparisons.
SAE Oil Viscosity is measured in centistokes (cSt) with a higher number representing greater resistance to flow or thicker oil. Measured at 40C (104F) and 100C (212F) operating temperatures with the number in front of the W indicating Winter or cold operation. As previously stated, based upon the factory’s Transmission specification for SAE 30 non-detergent oil and not being aware of a standard operating temperature range for our Transmission/OD operating temperatur, I would base my fluid comparisons at the high temperature reading rather than the low.
@ (104*F) / @ (212*F)
SAE 30 98.0 cSt / 11.4 cSt
5W40 87.2 cSt / 14.7 cSt
10W30 71.8 cSt / 11.5 cSt
10W40 96.5 cSt / 14.7 cSt
20W50 170.0 cSt / 20.2 cSt
Given the factory specification of SAE 30 provides an 11.4 cSt at operating temperature and this viscosity can be closely reflected with a multi-viscosity of 10W30 or even 5W30 it could be logically expected that choosing one of these alternatives would provide the Transmission/OD with greater protection and greater longevity. However, it would still take actual experience to validate the performance of the Transmission/OD and if it meets personal satisfaction.
It is much more of an open question that choosing a multi-viscosity oil that substantially jumps the operating viscosity, such as 20W50 with a cSt of 20.2 or approximately 177.2% increase over SAE 30 will benefit operating performance and will be more dependent upon operational experiences to justify the change. However, choosing a 20W50 lubricant with a Ware Protection rating greater than the replaced oil will still provide better protection even if operating performance is found to suffer.
Now, when looking at the targeted oils listed within the 540 RAT blog, Castrol Heavy Duty 30 wt. conventional oil holds the highest rating for this viscosity at 88,089 PSI while a multi-viscosity 10W30 from Mobile 1 Advanced Full Synthetic registered a PSI of 115,635 and at 20W50, Castrol GTX, API SN conventional, at 96,514 PSI, holds the record for this oil type. Given these reasonable choices, price and actual experience in operation would be the final selection triggers.
As a result of my analysis, I expect to change my present Transmission/OD fill from Red Line 90 to a 10W30 from Mobile 1 a similar viscosity profile of a conventional oil.
That’s my thoughts, what do you think?
Ray(64BJ8P1)
Ray(64BJ8P1)
Hi Guest!
