A friend of mine welded it, mig or tig I cant remember which, and no problems with the finish, you cant tell from the outside.-----After rechecking my cover the plate I used was 1 1/2" and I left the ends open 1/2", I angled the baffle out to where it rested against the large round casting supports for the mounting bolt holes. [/quote]
Allan,
That's fantastic, and it's what I will do. But I still don't have the exact configuration. But before we go on, do you happen to know if your arrangement will work with the stock rocker assembly?
So your baffle uses a 1 1/2" wide aluminum strip, the length of the valve cover (except for 1/2" on either end)1/8" thick. Right? Did you say there is a bend along the length of the strip, or is it just angled out slightly from the wall of the valve cover to allow the gases to pass? Is there a bead of welding the entire length (top and bottom?) or just a few tacks? Are there any kind of holes drilled in the bottom of the strip to allow the oil to drain, or does it just weep out of the ends?
Thanks for the help. It may take me a few weeks, but I'll share the outcome with everyone.
Allan,
Hi Guest!
