Alloy cylinder head
mgtf328
My BJ8 has a Rawles motorsport alloy head and puts puffs of blue smoke out when it starts from cold, valve seals I expect.
I've been stoking myself up to change them and now the "virus" seems to be creeping back again I have no excuse other than I have never worked on an alloy head before. I tend to make sure that nuts are tight enough! So I'm a little bit afraid that I might do some damage by overcompensating and not tightening them enough or stripping some threads. I also suspect that the torque on the head and manifold bolts should be a lot lower than the Bentley manual indicates.
So can anyone tell me what the head and manifold bolt torque's should be. I've googled it and come up with nothing so far.
Any other advice on working on alloy heads would also be welcome.
Thanks
AJ
Madflyer
I do not think there would be a problem with OEM torque that being said did it come with a head gasket and new head bolts. There is a rotation to tighten bolts and a recheck after so long. What about the lower end new rings ; cast, chrome, and how many steps cut on valves two or three. And fall back on Rawles. Is block true? heating and cooling of different metals can cause unknows problems. Best of luck tell us what Rawles said and what you find. One for all ! all for one ! Madflyer
John Turney
I have a Denis Welch aluminum head and torqued the head nuts per Bentley. The only things I worry about are the spark plugs. Be sure to lube or anti-seize those threads.
Dandare
the temperature of the head when retightening is important. Alloy heads are usually done cold so check this with the manufacturer.
Danny
johnea
There is a way of replacing valve seals without removing the cylinderhead. You might want to consider that, if you're reluctant to remove the head . . . .
W Alloy Cylinder Head Or Not MG 13
wangdango 6-cylinder alloy valve cover Austin Healey 53
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
D MGB BWA Alloy Wheels MG 9
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M TR6 Alloy Wheel Upgrade Triumph 19
S TR2/3/3A Alloy flywheel Triumph 13
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
J Alum shroud alloy Austin Healey 7
M TR2/3/3A Alloy valve cover--new twist Triumph 10
M TR2/3/3A Alloy valve cover. pros/cons Triumph 6
JAV New DW alloy head Austin Healey 17
E TR4/4A Cleaning of alloy parts Triumph 4
H Alloy body Healeys? Austin Healey 5
TRMark TR4/4A Alloy wheels for 165R15 Triumph 10
MikeAH100M No Valve Cover Breather - Alloy Valve Covers Austin Healey 5
MikeAH100M Alloy Valve Cover Fasteners Austin Healey 3
jhorton3 Alloy Valve Cover Spridgets 18
johnrip Wedge tr7 tr8 alloy wheel tires Triumph 3
angelfj1 Alloy wheels for that authentic steel wheel look. Triumph 11
Hap Waldrop MGB A new alloy wheel choice for MGBs MG 11
R Alloy Oil Pan from Moss Austin Healey 9
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
M What is the alloy of steel used in the A-H body? Austin Healey 2
K Alloy Wheel Lug Nuts? Triumph 3
M What is the alloy of steel used in the A-H body? Austin Healey 4
Z Alloy Wheels Austin Healey 14
R Alloy Pedals BJ8 Austin Healey 4
johnrip Wedge tr7 alloy wheel needed Triumph 3
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
Hap Waldrop VTO 15x6 Classic 8 alloy wheel sale MG 3
B 3000 Alloy block Austin Healey 18
Hap Waldrop Performance Challenger alloy wheel MG 0
V TR2/3/3A Alloy Radiator TR-3B Triumph 46
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
texas_bugeye Slant alloy cover British Motor Corp 8
texas_bugeye Slant alloy valve cover Spridgets 2
T Alloy valve cover functional, or 'just' eye candy? Spridgets 14
M Alloy Valve Cover Install Issue Triumph 2
F TR2/3/3A TR3 "NonBreather" Alloy Valve Cover Triumph 3
Trevor Jessie Anyone in the market for alloy wheels Spridgets 13
Number_6 Recore or new Alloy Rad? Triumph 10
highlandracer Information needed: 3-spoke alloy wheels Other British Cars 0
