kennypinkerton
Hey Doc... I've got rust. Are the outer sills an integral part of the frame on my Alfa? (like on an MGB) Or can I just get some new sheetmetal welded in place of my rusty bits? It's pretty bad on one side, here's a pic after I ground the rust off the dogleg and primed it to try n stop it from spreading. You can see the bubbled paint along the sill - it's just as bad or worse. The driver's side had on little bubble that turned out to be a single rust spot about the size of a nickel. The rest of the car is fine (except the floorboards in an area about an inch surrounding the rubber plugs I forgot to remove when you told me to.
What's your thoughts?
