Alfa 4cyl engines
TRMark
Bronze
Why are they mounted at about an 8 degree angle? The twin cam head is wide so I can't see it offers a lower hood. Oil pickup maybe? Restoring my old sports/racer with alfa 1600, the engine would fit better upright. It has a conventional steel sump, not the batwing. Also thinking of replacing the Alfa with a 1275, it would be more appropriate, since the front and rear suspensions, wheels are very early 50's Cooper. But the Alfa is light and put out good power.
waltesefalcon
You should try asking Doc, he's our local Alfaista.
TRMark
TRMark
Bronze
I was hoping he would see the post. I posted on the AlfaBB as suggested. Seems the only reason the engine is tilted is so the Webers clear the inner fender.
waltesefalcon
"Seems the only reason the engine is tilted is so the Webers clear the inner fender."
That sounds like something Alfa would do.
LarryK
Most Euro cars, Jag, Ferrari, Alpha have done this for low hood (bonnet) for aerodynamics.
Platinum
Sorry I'm late, Mark.
Only explanation I ever heard was to accommodate the Webers. The '60's~'70's models I'm most familiar with used a "giubo" flex-joint at the trans output shaft and U-joints at the rear and middle, with a support bearing and slip-joint at the center. Always thought that giubo was a method to compensate for the canted engine. More compliant than a four-point U-J, less likely to wear as a result.
That 1600 should put out much better power than a 1275! And certainly a more elegant piece of kit, as well. :wink:
I love my iron block Brit engines but where twin-cam designs are concerned, Alfa takes the prize. I've personally owned 1300, 1600, 1750 and 2L Alfas, professionally worked on all at a dealership. The best for output vs. size and weight are the 1750's, IMHO.
NutmegCT
TRMark
TRMark
Bronze
I did not find that discussion when I searched the alfabb so I started one. https://www.alfabb.com/bb/forums/en...rebuilding/673832-alfa-1600-engine-angle.html I received a different set of answers and a discussion about Webers. I am not buying the leveling during torque argument. Alfa engines seem to tilt 5 to 8 degrees, that is a lot of torque movement to bring to level, more than broken motor mounts. The oiling issue was not brought up in my thread. And yes nothing looks better in a sports/racer then a twin cam.
P Alfa Spider Other Cars 1
P Alfa telephone repair Other Cars 2
DART Alfa Other Cars 2
glemon Alfa Romeo 4C Other Cars 10
steveg [OFF] Great Leno Garage vid driving Alfa 8C 2300 Monza Replica Austin Healey 1
glemon MGA and Alfa Scottsdale Spotted 0
DrEntropy Alfa gearbox issue Other Cars 2
T I need some help with an Alfa Romeo.... Other Cars 4
DrEntropy Alfa gearbox lunched Other Cars 16
DrEntropy 'nother Alfa Spotted 1
aeronca65t ALFA Spotted 5
Moseso 198something Alfa Spyder Veloce Spotted 1
C OT - Are Alfa's better? Triumph 19
DrEntropy Alfa throttle linkage? Other Cars 3
BugeyeNJ58 British and Italian Cars..Anyone owned an Alfa? Spridgets 20
Gray_Cat Alfa GTV 2000 Project Other Cars 4
bgbassplyr Alfa Giulietta..... Spotted 0
AngliaGT Alfa Berlina Spotted 8
T OT - Alfa arrived today Triumph 33
D Alfa Romeo Spyder Spotted 1
bgbassplyr Alfa Spotted 12
bgbassplyr Alfa Other Cars 1
DrEntropy Alfa wearin' [out] a speedo [cable]. Other Cars 5
T Learning about body work....Alfa Progress Other Cars 13
toysrrus `87 Alfa Romeo Milano Doors For Sale: Other Cars 2
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
H Alfa Weber Carb Porn Other Cars 2
kennypinkerton Alfa Tinworm diagnosis... Other Cars 13
Flash MINI dealers to sell Alfa Romeos in the U.S. British Motor Corp 3
DrEntropy Just looked at an Alfa Other Cars 19
AngliaGT Hey Doc,is this an Alfa? Other Cars 13
B Paint systems explained: from Alfa BB Spridgets 4
kennypinkerton Selling the Toyota and maybe the Alfa Other Cars 2
H Alfa rally from Orlando to St. Augustine Other Cars 5
DrEntropy Alfa starter, round two! Other Cars 11
KLUTZ Parrish top for Alfa Romeo owners out there.kijiji Other Cars 1
H Traded 81 Alfa for 72 B and parts MG 7
H My new Alfa Other Cars 16
kennypinkerton For Doc... Alfa Pic. Other Cars 11
kennypinkerton The Alfa won... Other Cars 12
kennypinkerton Alfa Question... Other Cars 10
kennypinkerton Finally buying Alfa Spider parts... Other Cars 13
H alfa 5 Other Cars 9
H alfa 4 Other Cars 0
H alfa 3 Other Cars 0
H alfa 2 Other Cars 0
H alfa 1 Other Cars 0
H Alfa show in Celebration FL Other Cars 5
DrEntropy Alfa "Quality Time": Other Cars 8
H Alfa seat belts Other Cars 0
