RJS
On a 1966 TR4A, does the crankcase need to be airtight for the PCV to function properly?
As some of you may know, I have a slight crankcase pressurization issue with my engine. The TR4A runs a PCV from the valve cover to the intake manifold. The PCV is supposed to modulate the vacuum from the intake and create a gentle vacuum in the crankcase, thereby venting the crankcase.
What I am wondering is if the seals/gaskets are shot (oil pan, valve cover, timing chain, fuel pump, etc) is it possible that this permits high flow through the PCV but never generates enough vacuum in the CC since so much air is leaking in? Then, the high flow causes the PCV to close resulting in the CC pressurization I am experiencing.
Thoughts, comments??
