For the first time in ... quite a while, I removed the fuel sediment glass at the TR3 fuel pump. As the fuel cut-off valve was removed many years ago for some reason, the fuel in the lines drained out when the glass was removed.
Poured out the crud, then put the glass back in place.
Ever since then (Friday), the engine starts quickly but then just stops in about five seconds. Regardless of choke position.
Engine doesn't cough or run rough - it just dies, as if the ignition were turned off.
I see gas entering the clear plastic fuel filter (just before the carbs) when I pump the priming handle.
Does this sound like I have air in the fuel line and/or pump? If so, how can I "purge" the line?
Thanks.
Tom
Thanks.
Tom
