Ed_K said:I want to order a couple of these from Cape International,
https://www.cape-international.com/capeshop.php?parttypes=19&thepart=RP3
But where does one connect the crankcase vent hose when using
these ram pipes ? Does anyone use these and if so, where did you connect the crankcase vent hose ?
Just reverse it and let it hang down this way you can produce a negative pressure at its end.
It is always good to have a COMPLETE plan before purchasing parts for a Healey modification .
Thanks !
FWIW---Keoke
Ed
Keoke said:Just reverse it and let it hang down this way you can produce a negative pressure at its end.
dougsmarkIII said:On early cars before PCV valves they were called draft tubes. Keoke is correct they work by creating a suction when air blows by the tube.
Yes Dough, early engines where vented by the use of a
Draft Tube :thumbsup:-----Keoke
Doug
