TR2/3/3A Air deflector order of assembly
Crankshaft
Just returned from the paint shop and preparing to re-assemble the front apron to the body. Since it has been 7 weeks since dis-assembly, and at my age, what is the proper sequence of assembling the apron and deflector. Is there a choice or a preference?
TR3driver
Great Pumpkin - R.I.P
I've always installed the apron first, and then the deflector. The apron moves around a fair amount while you're getting everything lined up (I recommend getting all the bolts started first, before snugging up any of them), and I'm not sure how well the deflector would move with it.
Crankshaft
Crankshaft
Thanks for the response. I do seem to recall adding the deflector with the apron installed (through the grill opening) but I just thought there might have been a better way. I'll proceed just like I knew what I was doing.
Thanks again
luke44
It looks inviting to attack the deflector with the apron off as the access is so good. But don't be fooled, you need the apron in place to help locate the deflector relative to the rad. It's really not too bad. My car never had holes drilled for the horizontal lip so I never drilled new ones, just relying on the 2 chrome support brackets. This thread may help.
https://www.britishcarforum.com/bcf...ator-Air-Deflector-Shroud&p=946532#post946532
RC64
Phil...
I was about to make the same suggestion but Bruce beat me to the punch. The trick for me was getting a good fit around the radiator. The apron was already on so I had to go through the grill opening. If I had the choice, I'd do it again that way. It took some fiddling to get the shroud shaped to fit properly, but it worked out fine. The thread Bruce referenced should be a help.
Rick...
Crankshaft
Crankshaft
Following this advice I installed the shroud today and it fits like I knew what I was doing. Thanks to each of you for the input
B Air Deflector Assembly Austin Healey 2
55modified need help with custom air deflector for BN1 Austin Healey 12
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
H Rad intake air deflector plates Austin Healey 6
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
I TR6 radiator air deflector recommendations Triumph 10
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
Stinger TR4/4A TR4A Air Deflector Duct Triumph 1
E Air Deflector Color Austin Healey 13
H Air Deflector Assembly Hardware Help Request Austin Healey 2
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 2
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
