Johnny
Thanks so much Jerry, I now have perfect lights all around. you were so right about having the light leads reversed. Fixing it was a problem though. When you look at a dual filament bulb as used on the early model Healeys you'll find one filament stands above the other. The one on top is for running lights and the one on the bottom is for flashing. Both are used for braking but you can see the lower one flashing even with the brakes on because it becomes intermittent. This is an important discovery for me anyway because I always thought it didn't matter which connector you put the two bulleted wires in, but trust me it does matter.terp83 said:Johnny-
I had a similar problem a couple of years ago, but with both sides. I found that the red and striped (brown/white?) wires to the taillamps were reversed. I have had no problems since switching the wires back, and now am actually running a LED light through each reflector pod with no problems. Another symptom that I had before correcting the problem was that when the trafficator was engaged, the green indicator bulb would flash 2-3 times, then not flash anymore. My Healey is a 1962 BT7 and is converted to negative ground.
Jerry
Hi Guest!
