davidb
I have read with interest a number of comments and suggestions from BCF members on the types of engine oil for my Brit mutts, and as a result have decided to give the synthetics a try. Normally I'd use Castrol GTX 20-50, but I'll now be on the lookout for Valvoline VR-1, or Castrol Syntec 20-50, as suggested by the BCF experts. The question I now have is (and I couldn't find any previous threads that dealt with it), what types of spin-on oil filters are others using? If memory serves, I'm using FRAM PH 3600A, but a recent thread suggested that FRAM may not be a particularly good choice for the Big Healey. Any other suggestions (including the codes if you remember them)?
I also plan on using Redline MT-90 in the tranny.
On another quick note, I changed my brake fluids a couple of years ago from Dot 4 to synthetic, and found that the brake pedal got rock hard after some months. When I changed the front caliper brake hoses, I found that they were badly plugged up. Is this sheer coincidence or does synthetic brake fluid somehow react badly with rubber, after using standard brake fluid?
Sorry for the long post. It's lonely up here in The Big Igloo.
Thanks Dave
Thanks Dave
Dave
but a recent thread suggested that FRAM may not be a particularly good choice Any other suggestions (including the codes if you remember them)?
there is sufficient evidence to indicate that the synthetics are not compatible with original rubber brake parts.
If so it must be non-overdrive?
