YakkoWarner
I have a question about something I have zero previous experience with. I purchased for my MGB (4 lug hubs, not spline) project a set of very nice looking 70's vintage 14x6 inch alloy custom wheels that were reported to have been removed from an MGB-GT. The hole pattern is proper, but these are wheels that have very large holes which need inserts between the stud and the wheel. These were NOT included. There are a wide variety of these inserts - but I know nothing about getting the right ones. Since the holes in the wheel have no taper, I am assuming that the inserts need to be a tight (almost press-in tight) fit to eliminate play, and the inserts will have some kind of taper for the lug nuts to center up on? I have found a couple different inserts that feel too loose to me - they can visually move around in the wheel hole. There doesn't APPEAR to be any elongation or obvious wear in the holes of the wheels themselves.
So does anyone have experience using this kind of wheel/insert setup that could lend advice?
Hi Guest!
