The sender unit for the aftermarket gauge must be used to replace the ether bulb one just under the t-stat housing on the starboard side of the engine. If you intend to have the combo gauge redone, try to keep the tube intact as you remove it. Nisonger gets about $150 to rebuild 'em, but they are the ones I've used for decades. Check the threads and O.D. on the replacement sensor for compatibility, too.
