Hey Guys. Just bought a starter from RockAuto for my 66 mgb 1.8. It looks similar to a GM starter with the solenoid mounted to the starter. It can only be mounted with the solenoid facing down. There are a few tabs on the solenoid. Has anyone used one of these to replace their original unit and I'm assuming you have to remove the original solenoid from the fenderwell?? Also, what wire connections go where on the starter??
I guess my assumption is that it will also spin the engine in the correct direction, CW viewed from the front and CCW viewed from the rear. At least, that's how it looks based on the old flywheel ring gear. Guess I'll have to test it before putting the motor back in.
Thanks,
Chris
Thanks,
Chris
