jlaird
Pulled the flywheel and the back plate, Miss Agatha is not leaking from the oil pump cover, dry as a bone.
Best I can tell at the moment it is not leaking from the scroll seal either. That area seems dry as is the back of the crank flange, the quarter inch of crank that I can see, flywheel, etc.
It looks, more to follow tomorrow, that it is leaking from below that, like at the rear of the oil pan. Sealed with form a gasket though. I will also try to take a pic or two but is kind of tight in there.
The run is down the rear of the oil pan from below the crank as best as I can see tonite.
Will have more tomorrow when I can see more, may have to put the engine up on the work bench even so I can really see good and determin if as it seems that it is not the bottom of the scroll seal.
It is not fun to have old eyes.
Comments and ideas welcome as always.
