RAC68
As I see it, your choices are both reasonable and consistent with past approaches assisting the elimination of unwanted heat build-up in the compartment. Style is also a consideration to every addition and both approaches draw different points of interest for the eye. I, personally, happen to like the addition of fender vent design points on a 100-6/3000 as it accentuates an area that is uncluttered. This, in contrast to louvers installed in a bonnet area that already is sufficiently sculptured. Additionally, if you were ever to want to return to original, applying a flat patch to a fender would be no more difficult than replacing a bonnet and could be done without acquiring new.
Again, the choice is up to you,
Ray (64BJ8P1)
Ray (64BJ8P1)
Hi Guest!
