Barry_Osborne
I have a 59 sprite and got almost everything blasted and disassembled. I am getting ready to primer and paint everything under the bonnet and get started.
I am looking to convert the front brakes to disk and while I am at it, change out the suspension and help with a few handling mods. I am switching to the 400lb springs and a Âľ sway bar with solid mounts.
Is Âľ too much?
Any thoughts about tube shocks versus the original shocks? What brand tube shocks are the preference and the cost isn’t going to burn?
I was looking at this setup https://www.spritemania.com/web/Item/C%2DGSA200/AddedFrom/CatBrowse%2D%20SUSPENSION/InvDetail.cfm
I notice that they have the old shocks still mounted. I am wondering if this is just to keep the upper control arm? I shouldn’t rebuild the old shocks also, should I?
When I swap out the new parts for disc brakes, do the original tie-rod ends fit on the new “midget” A arms? (Yes, the tie-rods will be brand new.) Or should I get new tie-rods that are for the newer midget steering rack?
By-the-way, I am still looking for all of the brake conversion “gear”. If anyone has any leads on a disc brake conversion, let me know.
Lots of thoughts and questions—thanks!!
Is Âľ too much?
