TR2/3/3A Advice for which head gasket material is best
Joel Lester
My engine is at the machine shop and got a call from the machinist today once he had a chance to measure and evaluate everything. Overall everything looks good. Yay! I've got a set of the 89mm piston and liner set. The liners are "spot on" for their height above the block as long as I use the steel figure of 8 gaskets (I dropped off new copper ones too but he says they're too thick so according to him I'll stick with the steel ones).
He asked me about what type of head gasket I was planning to use - I told him that I've only heard about the copper ones. He said he didn't like copper head gaskets as much because you are having to keep re-torqueing the heads. I jumped on the internet and I soon realized there are a number of choices! Copper, steel and premium composite. You guys have any advice or input into this decision? I'm planning to be a weekend cruiser and have a new "road cam" from Newman cams so don't think I'll be needing to raise compression or doing any racing.
What's your head gasket of choice?
Joel
Hamish Racing
Copper should do it and easily trimmed for 89mm.
But if your engine builder doesn’t like them just go premium composite. Or what he recommends.
ive just taken delivery of a fast road engine and I went with all recommendations for their usual build. If you dictate changes to this and something goes wrong ( your part or unassociated ) there is an excuse literally built in.
you are investing a lot of money in your project don’t skimp on something that (hopefully) you will never see again.
H
Joel Lester
Joel Lester
Great! I got a call this morning that my engine is ready to be picked up! Super excited. I'm going to run this composite gasket idea passed him to see what he thinks. Also seems to be pretty standard item and a straightforward part. I hope I can tell which side goes "up" - perhaps it's labeled??
Thanks,
Joel
sp53
I used copper, but again doing what they suggest is probably best. I am not sure about a bunch of re- torqueing. I usually re-torque one time and it seemed tight anyway, so not sure if the torqueing is basically just checking to see if the head loosened. Heck 100lb is a lot.
I am putting a zinc additive this time because I had a cam lob failure using the old cam. What a nightmare, it took me months chasing a miss to figure out I had a cam failure.
steve
DougME
Here's something I found on the internet but have not done. Small dia. copper wire soldered to the head gasket. Comments ?
Joel Lester
Joel Lester
Thanks guys,
I picked up the engine parts from the machine shop. They did a wonderful job and I'm excited to get going. When I mentioned the composite head gasket idea the two machinists I talked to agreed that would be the way to go - the words that stood out in my mind were "much more forgiving". So that's the plan for now.
Cheers!
Joel
RJS
I went Lucas composite 5 years ago when my left rear head stud failed. Went with all new ARP head studs, re-torqued twice and never looked back.
When doing the original torque, I did it in incremental phases at 25, 50, 75 and finally 105 lbs-ft with a 24 hour period between each
PS: my motor has 87mm pistons
Andy Blackley
Concur of the ARP head studs, I used the same and I should have mentioned it. The small (relative) extra cost is well worth the piece of mind.
dklawson Spitfire My Spitfire Mistake - Advice Needed Re. Head Gaskets Triumph 14
B Cylinder Head - Need advice Spridgets 5
I TR6 TR6 cylinder head rebuilding advice Triumph 15
I TR6 Tripod head light advice for TR6 Triumph 9
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
