Nunyas
I hate to be the one to dig up old threads, but...
I recently acquired a spare ZS (got it for $30 on eBay /ubbthreads/images/graemlins/laugh.gif) that I've scalped for several parts. I've also installed a new fuel pump that seems to be delivering much better fuel pressure than the one that was already in the car.
The Air piston needle was the first part I nabbed out of the spare carb, because when I compared the "spare" to the "original" I found the "spare" actually came to a point where the "original" was clearly blunted flat where the tip should have been.
The other parts that I scalped out of the spare were the float and float-bowl needle valve. I nabbed these because I remembered someone mentioning the float drop may not be enough(?). I've gotten them installed but the problem is still persisting (poor/hesitant acceloration with flat spots at higher RPMs). I used the washer (a relatively thick one) that was installed with the valve in the spare carb and set the float height to about 16mm. Despite the use of the different valve, washer, and float, the fuel filter is still completely emptying and not refilling while the engine is running.
I have to ask, how do you make the float drop the right amount to allow the fuel to flow enough into the bowl and keep the filter at a relatively constant level on these ZS carbs? The design places the valve very close to the pivot axis of the float which in turn would require the float to move more to allow the valve to open than if the valve were placed in a position further from the pivot axis.
Finally, since I can't physically alter the float travel (relative to the valve), does that mean that my only option is to keep setting the float height to a higher level (smaller measurement since the ZS's float height is measured upside down)? And keep doing so until the fuel filter no longer completely drains itself while the engine is running?
As always, thanks again for any words of wisdom that you guys might impart upon me. /ubbthreads/images/graemlins/smile.gif
