Adjusting headlights on a BJ8
NIB
Had very bad light on my BJ8 when driving at night time. Decided to replace the sealed beam lights with H4 halogen. It didn't give the improvement I expected.
Checked the setting of the lamps and they were pointing 5-6% downwards even with the adjusting screw fully in.
Had to shim up both headlights with three washers on each lower screw to get them to around 1.5%.
Is that to be expected?
I had that problem once. It was bad body work.
:savewave:
Patrick, had that problem once. It was bad body work..
Yep I :iagree: that will sure do it---Keoke
