Adjustable steering wheel removal
Walter74
Member
Hello fellow enthusiasts,
The adjustable steering wheel of my BJ7 will not come off (when sitting behind the wheel). I have already ruined the plastic ring:sorrow:
The collar should be turned clockwise to loosen, correct?
Any good tips to get the .... off?
Thanks,
Walter
Use a rubber strap wrench to grip the collar also use a rubber mallet and tap all around the collar to break the age bond prior to using the strap wrench .
Finally got it off. Spline was heavily damaged. Unfortunately the steering wheel did not make it through the battle....
