Hi There,
I have several questions someone might be able to help me with regarding Overdrive on a TR3B
I purchased the car recently and it has an older TR3A gearbox in it without 1st gear synchro (someone replaced it at some point in its life) Originally it had overdrive but that is now gone. So I'd like to replace it... I do have some parts but would like to know what I need to complete the conversion. Here's what I have.
1) TR3 gearbox working fine in car
2) TR4 gearbox working not in car
3) rebuilt OD unit working not on a gearbox, Serial# 22 1374 005133 GB# 456007 (i purchased it along with 2 shafts and gears)
4) TR4 input shaft and gears
5) TR4 mainshaft and gears
6) adapter plate for OD to TR4 gearbox
7) extra TR4 gearbox housing
I don't know if the extra output shaft is for an OD or standard box. The owner couldn't remember. I can't see a part number on either shaft so I'm assuming its on the shaft under the gears. I read that the OD mainshaft is 1/2" shorter but I don't know what the length of the standard shaft or the OD shaft should be to measure the one I have here.
Questions:
How long is an OD mainshaft or standard mainshaft?
What do I need to add the OD to the standard TR4 gearbox I have?
I appreciate any help someone can offer.
Cheers,
Adam
Questions:
Cheers,
Adam
