Added gas struts to front tilt
David_Doan
Added Gas struts from the base of the radiator support to the top of the reinforced cowling. Adjusted maximum opening to leave about 2″ (hopefully) between the signal light lens and the ground. I measured that I needed struts that went from about 10″ to 15″. The local Autozone had a nice selection on a rack, the closest they had was the MightyLift E95091, 14.5″ extended, 9.25″ compressed. There were two in this size, these had the higher weight rating. They are not stout enough that you can just push it closed and let it fall, but they do make it easier to open and hold it open.
After some adjustments, the shot lines are pretty good. I'm still looking for a good replacement for the rubber piece that runs across the scuttle between the car and the bonnet. The old one fits but it is petrified. I have a ~20 year old new one that came with the car but it is too wide and too tall.
Jim_Gruber
David,
McGregors/MacGregors in CA provides a correct bonnet seal. They advertise in the back of Classic Motor Sports for example and sell the BristleFlex Door Seals. Their stuff, contrary to the seal that comes from the usual sources does fit. Best to give them a call. They have an 800 #. They don't respond to e-mail very quickly.
I like the idea of what you've done. Another alternative to stops or wire. I don't see any teflon washers in there at the pivot point. Did you use teflon bushings to make things easier to open and move? Alignment on bonnet looks really good. Additional reinforcement around the sheet metal will make sure bonet opens and closes without affecting surrounding sheet metal and the added bracing around the wheel arches makes sure cracks will stay away. Great Job!!!
Jim_Gruber
But call him. Great guy with a Scottish Accent. He doesn't do well with E-Mail.
Looking at those pictures ... looking at this old linear actuator left over from a streetrod project ... scratching my head ... you guys need to quit distracting me.
David_Doan
I thought about that too...the issue is leverage. In the closed position, the strut is only about 2" away from the hinge point. It would take a lot of force to open it. The gas struts I used are about 40 lbs force each. They have little effect when the bonnet is closed.
Stop it! You're making me think about it again. This linear actuator is rated at 1000lbs dynamic load.
David_Doan
That's exactly the problem. It would take a lot of force to open from that position, the bonnet probably can't handle it. And imagine what would happen if you pushed the button and it was latched down.
Jim_Gruber
David,
Painting this weekend? Pics?
David_Doan
David,
I've not started yet... partly due to work (I travel for work), and partly due to family stuff. You'd think the 3 day memorial day weekend would be a good time to get stuff done, but there were too many family events. I'm also intimidated by paint and bodywork. I'm a good mechanic and I'm handy with a spray can for small parts, but painting a whole car is virgin territory for me.
Today I bit the bullet and ordered the paint, 1 gallon each of Brightside White Paint, Primer, and Brushing thinner. Probably a little overkill, but 3 quarts is about the same cost as a gallon then add shipping for a second order and having to order one extra quart costs a lot.
Best price is jamestowndistributors.com and they have a flatrate shipping coupon right now - $9.99 and no tax.
I decided to do one door as a confidence builder. I will start a new thread for that.
One thing i'm trying to figure out the best way to manage... there are places where the original paint is flaking off down to the metal. I hit those areas with a wire wheel and work outward until the paint stopped coming off. Do I use filling primmer to raise the low spots OR skim coat OR strip the whole panel to bare metal (that would be most of the car)? I'm leaning towards good sanding and primer.
Jim_Gruber
I think sand and fair in as needed. If you go with a high build primer make sure compatible with the Brightside paint. If you ordered their Primer which I think you did you should be good to go. There will be some areas like under the bonnet, no you already used undercoating there, where it is an advantage to spray vs. roll. I already know there are a few spots where I will need to get Bugsy II out in the open to keep fumes out of the garage / house and keep my wife happy. I'll be curious as to your comments on noxious odors from Brightside Paint. Rustoleum rolled in a small garage is very tolerable. And my wife's asthma was not bothered by Rustoleum. Please let me know how the Brightside Paint did in the garage. Brightside thinned properly and applied with a roller has some great self leveling qualities. And it is a hard, hard paint. I've used before on centerboards and rudders and it always worked well.
2.8 cologne
Do your bonnet gas struts equalize the the pressure when opening and closing at the body cowell? I need something to keep the bonnet level at that point.
78Z Added gas struts to hold up hood [bonnet] Triumph 3
Editor_Reid Memorial Information Added | Kent Lambert, RIP Austin Healey 10
vping Added to my collection Other Cars 5
T I added another TVR to the fleet. TVR 10
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
trrdster2000 Spitfire Added a few pictures to my Photo Album of the Spit6. Triumph 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Zitch TR4/4A Door Weather Strip Channel - Was this added? Triumph 4
W Just added this to the collection Spridgets 6
3798j TR4/4A Added an Oil Catch Can Triumph 8
T TR2/3/3A TR3 top/bows fitment and added strap Triumph 2
R 100 Registry Added Austin Healey 0
J Size of disc caliper mounting bolts? Picture added Spridgets 3
hondo402000 Added new hole for Tach Cable Triumph 7
M_Pied_Lourd Added another one to the Family Triumph 31
Nelson Third brake light added Spridgets 18
J TR2/3/3A chance to buy dads TR3A! Pic added Triumph 51
jvandyke added door handles? Spridgets 21
Tinkerman TR2/3/3A Radiator overflow pipe clip TR 3A [pics added] Triumph 9
TR4A_IRS TR5/TR250 Have you added 3 point belts to your TR4/5/250/6? Triumph 10
Brosky Stag Trimph TransAmerican Stag pics added to DOT Triumph 24
B MGB-GT Another 67 BGT added to the fleet MG 8
B 1.5 new MG's added to the fleet! MG 11
tony barnhill Another XJ6 Added to the Collection Jaguar 15
Tinkerman New British Car Club Formed! [Pics added] Triumph 4
regularman Just added up my gasoline bill. Spridgets 7
jackq another small SUV added to the herd Other Cars 1
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
Brosky Frame stripping started- added pics 11-03 Triumph 11
jlaird I added some pics Spridgets 0
Z epoxy primer-added another part to it Spridgets 21
J Spitfire Third brake light added to my Spitfire Triumph 2
SCguy Wedge More TR8 questions and pictures [more added] Triumph 17
vping Engine Noise - Video 1 & Video 2 added MG 59
PAUL161 Another member added to the family?? Oh my! MG 18
Brosky LED Lights on Roll Bar for safety-more pics added Triumph 8
Basil Type A Overdrive Article added Austin Healey 2
jlaird Added a photo Spridgets 6
jlaird Added a new pic Spridgets 0
tony barnhill Added Another One Today... MG 24
jaybird Today's photos added MG 9
jlaird Three new pics added Spridgets 1
Steve Added one to the fleet Other British Cars 7
S Added a new car! Other Cars 11
C What gauge is this?.....added picture. Austin Healey 9
t8nwa New MINI pic added to the gallery British Motor Corp 1
Basil Another member's car added Jaguar 1
Basil Sunbeam forum added Sunbeam (Rootes) 2
L Gas Cap Recommendation Austin Healey 1
Celtic 77 MGB LeMans Gas filler MG 10
