Jim_Gruber
For the first time in months I actually got 3 hours of time to spend with Bugsy II today. I got inner fender to radiator brackets mounted and installed. 3 of 4 bolt holes on fenders had broken bolts that needed to be coaxed out with heat and one needed to be drilled out and tapped. PS Bracket loots straight but DS Bracket a little whopper jawed and will need to changed out as the way it is bent it does not sit level. Tatersalad on BCF has another bracket he is sending. Since plan is for Bugsy II to go on a rotisserie this winter I wanted the radiator standards to get as much additional support as possible.
I was able to fix and weld up a crack in the DS Inner fender right at the very front. 1.5" long crack in the fender that welded up and ground down quite nicely, One more small crack to fix and on to working on welding in the battery tray vs. the pop rivets that are in there now. Thought is to grind down to shiny metal, spot weld at seal and leave rivets in place.
