I finished stripping bare the TR6 frame yesterday and immediately noticed a problem at the right front corner. I am guessing this - the bent fulcrum pin and the torn away weld - is the result of an impact, unless this is a known weak spot and simply the result of age and hard driving. The body doesn’t look to have been crumpled at right front corner. Perhaps the right front wheel took a blow hard enough to do this. Any thoughts?
I would probably use some hydraulic assistance to tweak frame back into the ballpark. Right now that shock/spring tower is aiming a little low and inward as you look from front to rear.
I hope the images show up... don’t see them in the preview.
