jfarris
Greetings to all my quarantined friends and best wishes and prayers for those who still have to go out of the house!
I am putting the finishing touches on a modification to my 56TR3 to add brake lights to the rear outer turn signal circuit. My thanks to Randall (TR3driver) for the relay schematic and much needed basic electrical education. Thanks also to Marvin Gruber who wired the car during restoration for using a portion of a TR4 wiring harness so that the needed wiring was in place. Marvin also pointed me toward color coded wiring diagrams at http://www.advanceautowire.com/tr24a.pdf which are fifty times easier to read than a Haynes Manual! If you don’t have these, make that your next stop! They also have TR 250/6.
I have a problem that I have tracked down to an issue with the right turn Green/white wire between the bullet connectors close to the left hand horn and the control head. I’ve included pictures of the steering wheel on my car and need to know how to remove the control head to the point of gaining access to the turn signal wires. The head will move slightly outwards about ½” to ¾”. Is this the way to remove it or do you have to unseal and loosen the wires going through the steering box to gain access. It appears that once you get access to the back of the unit, there are three small holding the front on the unit.
Can anyone point me to a forum thread or better instructions. I looked in the Triumph Maintenance and Haynes Manuals and learned just enough to break something.
Thanks in advance!
Thanks in advance!
