Morris
I definitely don't need another project, but as it is unlikely my car will be on the road before the HOT gets here, I have been thinking of ways to keep the cockpit cooler.
One ideer I had was to use a Peltier cooler (TEC) to make an AC. I could fill the heater core with Ani-freeze, water and water wetter, plug it off, then adhere the TEC with thermal grease or epoxy. I could cut a hole in the heater box that would allow me to attach a heat sink to the back side of the TEC. Perhaps to save my stock heater box, I can fab up a custom one. Also, I will need to upgrade my alternator to drive the anticipated 175-200 Watt (15-16 amp) current draw. Finally, if find that I need a heater, all I need is a switch that changes the polarity of the TEC.
Soooooo.... what do all you engineers and other great minds think about this idea. Will it work?
