TR2/3/3A AC Fuel Pump Lever
71TR6
I'm rebuilding my original AC fuel pump and noticed part of the surface on the end of the arm that contacts the cam was rusted. I wire brushed the rusted area to see what was there and uncovered a pitted surface. I checked a spare pump I have that I'm rebuilding and that too shows some pitting. Is this something I should be concerned about? I don't want to risk chewing up a cam.
Thanks again!
Ron
DavidApp
What is the history on the fuel pump? Did the car sit for a long time?
In Georgia when we have a cold spell then it warms up there is condensation on every thing. Probable on parts inside the engine as well as outside the engine.
David
CJD
It won’t be good for the cam, but it will likely work. The load on the pump lobe is very low compared to the valve lifters. If I were rebuilding it I would work it on 120 grit paper to remove the pitting...then work it down to 600 grit to finish it.
Frank Canale
John, you have gone in the way I was thinking but I would be just guessing to offer a suggestion along this line . I would be curious if it took 1/16" (.063) to clear up the pitting how much that would effect the fuel pump stroke and if that would be a problem. Once I get to my engine I may be facing this problem as well. Frank
CJD
I think the lever is always in contact with the cam lobe. You can feel the tension of the arm against the lobe as you insert the pump, so there is some stroke to spare. I would think 1/16" would still give full stroke, but can't say for sure. Sounds like something to check out at some point.
sp53
I find this situation interesting to think about, the fuel pump arm looks like brass and the cam is some kind of hardened something. The cam is round and the lever flat plus I am not sure how much surfaces of the both touch and where. I would not like it, but the 2 must have been rubbing for a while. I would think the hard metal would polish the brass. Plus how did the levers get like that in the first place. My guess is the brass at a molecular level is like particle board and falls apart in microscopic chunks and leaves behind what we see to the naked eye. The valleys and mountains might be ok with each other and the brass with very very small pieces fall off into the oil. Yes the forum has been slow lately and I have an open mind.
steve
71TR6
71TR6
The fuel pump sat in the car since the early 80s and I'm pretty sure the rust/pitting is from contacting the cam and going through multiple hot/cold/condensation cycles over the years. I'm a little hesitant to sand or file it down since it needs to be perfectly parallel when it sits on the cam or it might make things worse if only an edge rests on the cam afterwards. Since it is relatively light pressure, what are everyone's thoughts about surfacing the roughness with some braze and smoothing it?
Ron
Sarastro
There's really no need to overthink this; I'd just file it out and smooth it with sandpaper. That may not be as good as new, but you'll get many more years of life out of it.
poolboy
I agree, just make it's surface smooth and don't worry about pits below the surface, they'll just be oil reservoirs.
71TR6
71TR6
Thanks for the input everyone! Yes, I think I overcomplicated/overthought this one. The sides of the lever are machined flat and provided a nice reference surface to sand out the pitting on the 6" wheel of my benchtop sander. It didn't take much and looks like it's supposed to now.
Thanks again!
Ron
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
eschneider fuel pump lever pivot pin retaining shims? Triumph 3
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
