So, for this story to make sense, you need to remember that when I was getting the car ready for the road I put on an HS4 SU to replace the Zenith Stromberg. At that time, and as a part of adapting the float, I tried to shorten the line from the float to the jet. As I dismantled this, I broke the rubber compression gasket which I found out was made of unobtanium. Repaired it with a couple of o-rings and thought I was good till I was driving with Mark last week and discovered that gas was dripping on the exhaust. Was visiting another friend last week and he had a box of SU carbs - anyone know what an AUD82 carb is for? Anyway, got a new line - new gasket - repaired replaced, tightened up the choke cable and started her up. Felt a difference even as it started but, didn't sound just right. Went back to the carb and the plate my mechanic had placed over the mouth because we couldn't get it to run right back then. Pulled the plate and OMG - it is a different car. It pulls like crazy, burbles like an SU should, it is astonishing! Even chirped the tires for the very first time.
What seems to have happened is this. The line was leaking all along - the car wouldn't rev because it was either drawing air and fuel or just not enough fuel. This gave too much air to the carb. The mechanic - not knowing about the fuel line - assumed the carb was too big, restricted the air and all worked again. Unfortunately, the fuel was still not coming as it should have. Hence the underwhelming performance, except I didn't know any better.
So, now I am very happy, the car seems to be running/ pulling as it ought - will need to tweek the idle in the daylight, but, woo hoo, If a pair of SU's makes her sing, a single makes her solo and I can actually drive her like I stole her!
