I have recently reassembled the two halves of the overdrive. I used a spare transmission main shaft to align the splines in the sun gear with the spines with the unidirectional clutch. The force needed to rotate the sun gear seemed excessive. I am wondering if the sun gear end float is insufficient, even though I reassembled the overdrive using the same thrust washer and adjusting washer that were in the overdrive when I disassembled the unit. These two washers set in front of the sun gear.
Any thoughts?
Thanks.
Ron
Any thoughts?
Thanks.
Ron
