Rob Glasgow
I was watching some YouTube videos about replacing door skins. I need to replace the bottom 5" of both my doors due to rust through. Interestingly, the door panels rusted right where the inner door bottom touches the outer skin. I assume that area traps moisture (or spilled coffee) and eventually rusts through. Same situation on both doors.
At the end of one of the videos, the fellow mentioned when he finished installing the new door skin on his Chev Pickup door, he planned to caulk the inside of the bottom of the door where it met the door skin to prevent moisture from collecting there. Light bulb went on! I thought that's exactly what I will do once I finish installing the patch panels to the bottom of the doors. A simple job to apply a line of silicon caulking on the inside of the bottom of the door where it meets the skin. In fact, something anyone with a side curtain Healey could do at anytime by just removing the piece of vinyl covered plastic in the bottom of the door pocket. Those with roll up window cars could also seal the seam if they ever had their door pockets open to work on the windows.
Just thought I would pass this tip along. Man, I love what you can learn on You Tube. Thinking about doing my own total knee replacement. Seen several videos and I have all the tools the Doctor uses. Sawsall, Drill, Hammer. What could go wrong???
