Mike_in_CA
When I bought my sprite three weeks ago, I had a feeling I would find a very common problem that my car had. The previous owner changed the engine to a 1098 and put in a rib case trans out of a 1275 car. What he did and what I was sure i would find was that he used the wrong pushrod for the clutch slave cyl. Most uneducated sprite ownes just assume that the pushrod is the same for all engine/trans combinations. There are in fact two different size pushrods that go between the slave cyl. and the clutch arm. The 948 and 1098 use a shorter pushrod then the one for the 1275. So, if your clutch is letting out very near the top of the pedal and you can not seem to be able to see why, then it probably has the longer pushrod instead of the proper shorter one.
