A tip for anyone changing their suspension bushes
G
This might be better in "tools".
I struggled so badly changing the rear trailing arm brackets (getting the old bushings out with a hammer) that I figured there had to be an easier way. I've been putting off changing out the front to match because of it.
Well I'm happy to report I found one. This will be old hat to some I'm sure, but I spent $39 on a 1.5 ton press that I fastened to an old workmate with a couple of C clamps. OMG what a difference. Removing the old bushings in the front was a breeze (I used sockets as drifts).
It's replaced the 24" 3/8 extension as best tool I've bought. (When I go back to the do the u joints in the rear half shafts the 24" extension will go back to being #1 of course).
One other thing if anyone is ever going to do the front upper a-arm bushes. It will save you some time if you go to hard bushes. It's tough (in my case impossible) to slide the wishbones back on - though with the old rubber bushes it came off easily. It looks like you should remove the fulcrum bracket. Save yourself an hour of aggravation by not even starting trying. You'll never get it off with the body on. With a wrecking bar and a bit of persuasion the inner wing will flex enough so that the wishbones can be pushed on the ends.
Note: My body has a 1/4" of some kind of hard underseal on it - this approach might not be necessary if yours doesn't.
A ball joint press work extremely well also. It's like a huge "c"clamp that comes with assorted adapters. It pushes out rubber bushings like they're not even there.
They're usually available to borrow from Auto Zone.
Re: A tip for anyone changing their suspension bus
HI alana,
I just replaced the rear bushings on my 6 this past week and it was a breeze! I didn't even have to use a hammer or a press. I read an old post here and modified the procedure a bit. What I did was got a threaded rod from the hardware, it was 7/16 X 14tpi, two coupler nuts two grade 8 nuts and some fender washers. I spent less than 10 bucks on the supplies. What you need to do is cut the rod down to 20 inches feed it through the sleeves, thread on the nuts and start cranking the wrench. The bushings popped out without too much effort. To install the bushings use the left over rod and pull them into place one at a time. To do that you need a piece of tubing with a 1.75 ID so that the new bush can pull into it without damageing it.
Don't know if the procedure would work on the front but it would have saved you a whole lot of bangging!!
