Hey Jerry,
TRF markets an extra piece of rubber strip moulding that seals the leading edge of the glass perfectly. My camera is out of pocket so I will try to explain. The first piece is a hollow soft rubber sealing moulding that has a base offset to one side. This mounts against the windshield frame with the base offset to the inside, against the fuzzy seal. The second piece is similar but has a base that is more T shaped and mounts against the fuzzy seal. The result is a double seal that perfectly seals from water and wind and the leading edge of the door glass snugs nicely against the the back edge of the front seal and the inside edge of the front of the glass slams or rolls up against the inside piece. Very tight seal that never gets in a bind. I think that stock only had one piece. This extra piece looks like it could be stock and works great. Call TRF and tell them you want the extra upper A post seal.
Hope this all makes sense.
Bill
