Jim_Gruber
The DPO of Bugsy replaced the Outer Sills which are in good shape but did a Bondo Job on the A-Pillars on both side. Looks like I'm going to be able to pick up a cheap MIG Welder in the next few days and some metal work can commence on Bugsy my '68 Sprite. Being a total novice at welding is it possible to remove and replace the A-Pillars without removing the Outer Sills. From what I can see, looks like Outer Sill needs to come off to get access to the A-Pillar.
How about a good source for a Welding Plug Cutter.
Hi Guest!
